The F16 kit looks great but there are some areas needed modification:-
The Kit recommend 1500mAH 3S lipo and a single servo using snake linkage . This will have to go or modified.
The steering nose horn is purely plastic(no metal re-enforce)...just too weak. Will be replace with a better ones
My comment:-
1)If you follow the battery size /capacity , the flight will be short so is the lifespan of the batteries.
2) I feel the single micro servo will be unduly stress by the snake type linkage so i opt to use 2 servos for the aileron controls.
3) Steering nose horn is replaced with a stronger and better ones.
The first thing to do is to get rid of the original location of the nose gear. Relocating the gear towards the nose vertex .
This modification make lots of room for a bigger size lipo battery and allows better protection to the nose during landing and take off. Am thinking at least a 2200mah 3S 25C or a better 3800maH 3s 25C or even 4S setup .
4) I opted to use a proven 70mm EDF setup rather than to re-test the stock fan. (got to save time testing the stock fan. Better use the time for building instead). I need to remove some foam so this particular 70mm could fit in.
more next time.
My comment:-
more next time.
