RC conversion for plastic scale model ship
    Originally posted by loyn View Post
    ya lor ...... so long already still NIB
    this was the pic taken few yrs back ...... now my kid already primary one
    Wow.....she really looks so "small" at that time......Yamato looks Big.......
    Build build build..................
    For the Love of Flying...
      Originally posted by devils_grin87 View Post
      the tamiya 1/350 gearbox cant fit the trumpeter ship ... i think i will mount the motor direct ... any suggestions for motor size ???
      I think 180 to 280 is more then enough for 1/350 scale. Especially if you plan to sail it at "scale" speed. If not it may transform into a PT boat
      I am using 180 because of the shaft alignment needed. 180 has a smaller can dia compare to 280 and it has a flat surface for easy mounting as well.
        ya she was young then ...... and growing up fast ......
          this may be out of topic but sure is related to conversion project.
          Super work done by others ....... transform a toy tug into a almost full scale tug ..... so nice The pic of before and after
          time to plan for mod project after the bismarck
            nice... Are you gonna display your ship during the SAF YC carnival?
            Hangar:
            IJN Yamato (RC, EP)
            fitted with workable searchlight
            1/350 Tamiya,
            converted from static
            DKM Bismarck (Static)
            USS Missouri (Static)
            Shipyard:
            Schnellboot S-100 Klasse (RC, EP)
            USS New Jersey (RC, EP)
            Home Waters: Tanah Merah (my condo)
            Boating hours: 9.30pm+ (night ops)
              dont mistaken that is not my boat happen to found it on the web..... so to share how toy can become a v scale boat that is all.
              Sorry dont think I will be there as I only have 2 urgly old boat
                worked on the Bismarck for the past 2 days and completed its floatation tank ..... also the cover for the battery and motor
                the compartment is made out of 2mm plastic and foam (blue foam)
                got to fix hard mounting point for the deck as well .....
                more work
                  finally done with the seal for the WTC ...... I used some rubber seal material so when the deck is mounted onto the hull it will "compress" it and form the necessary seal again water...... hope it work
                  the deck is hold down to the hull with 11 screw ..... and alot of hot glue on the WTC
                  time to paint
                    more work
                    Nice, but where did u get the blue foam from?
                      where else ......Artsfriend lor ...... but it come in 1 inch thick and you have to "cut" it down to the thickness you need ....... I cut it down to 5 to 6 mm with hot wire cutter
                      initial was plan to use it for plane but now become boat
                        I have been doing plastic models for years and it has been a dream of mine to make a rc conversion, but i dont know what parts i need or how to convert, anyone can teach?
                          You need a radio with 2 or 3 channel. More if you want to control other moveable part of the boat. I assume you are talking about 1/350 or 1/250 scale battle ship. A small prop.... 20mm, prop shaft and small motor, esc and small lipo batt.
                          If the building stops, the buying starts!
