Yep, you aren't seeing double,you read the title correctly, its my 3rd f-16 scratchbuild , and this time making it even lighter, faster and well,sexier.
Everything and all the steps down here are very similar to my previous f-16 build thread. So i won't be elabourating on the steps. Yes, i'm going to do a blackknights paintjob on this f-16 again and i'll do a better finishing this time round.
Reason for choosing whitefoam , thats right,the lousy breakable cheapo but very light foam that found in almost all hardware/popular/ bookstores in singapore. Its because i want to experiment whether flying a:
1) Heavy but tough and strong plane , higher wingloading
Or
2) Light but breakable plane , lighter wingloading
would actually last longer under my handling before it ends up in the rubbish bin. So far my bluefoam f-16 edf lasted me 1month,with about 15flights 4minutes each before breaking into pieces. Lets see how this plane will do
Some other changes i made in the plan is the FSA area, from previous of 120% intake 93%exhuast, i downsized to 100% intake and 80%exhuast. Which will give me a higher top-speed.
Alright,i'll start off by posting pictures, i started this 1week ago , 6hours each day and i'm almost done with my plane today.
I started by transfering all the plans onto a hard cardboard sheet, going to be use for hotwiring later on. Then i join up the pieces of foam to form a large block, 1m x 20cm x 20cm. Divided them and ready to cut pieces by pieces.
Or
