Sub nubie.. need some help
    Originally posted by loyn View Post
    a u using a Bi directional esc ? like those in the car ?
    btw what pump are u using can post a pic of it ? thanks
    I'm currently using a brush esc dat is used for airplanes.. do i need to use a Bi directional esc?
    I'm using MK electric fuel pump.
    zooooomm!
      Originally posted by Builder View Post
      This will be a useful information for you Submarine.
      http://mms.tiger.tw/upload/upload_fi...220_manual.pdf
      seems like it cant be opened..
      zooooomm!
        Get a brushed esc w/ reverse function. Like tis : http://www.jethobby.com.sg/cgi-bin/e...44&idx=1&gid=8
        I am also tinking of building one for fun. But too many other boat n heli projects on hand.
          ok that is a good ready to use pump for this kind of project , as I have plan to get one until I saw the price tag
          so your problem here is to use the right esc , you cant use a nor plane esc. As they are single direction control and use the full spand of the stick movement (0 to 100) To get the pump to work both way u got to use a bi directional esc. This will allow the pump to go both way.
          A cheap way out is using mechanical switch with servo to change the polarity of the power supply to the motor if linear speed control of pump is not necessary
            Loyn,
            Go to Mockingbird and get the Prolux one. Abt S$17+. I bought one already to test my boats' cooling system at home.
              Loyn,
              the pump is bi direction as well ? thanks for your infro
                Yes, the pump is bi-directional. They now having an offer, S$14.54 only.
                Quickly go n get it.
                  thks bro ....... can see today early lunch lor
                    any recomendations for a cheaper one?
                    zooooomm!
                      thx bros for de help! will get a bi-directional esc.. but i kinda looking for cheaper ones.. are de ones used for rc cars or boats cheap?
                      zooooomm!
                        Look for it at ebay. Dont wana post the link here, otherwise later ppl complain. Do a search on ebay, plentiful and chip chip too.
                          The RS5 switch is the ideal way to switch the pump on off with reverse, however it is going to cost as must as the ESC so probably the best way to go is reversing ESC.
                          And dont forget you need a failsafe device to blow ballast in the event of lost signal
                            is the failsafe device an extra controller that detect lost of signal and set servo to pre progroam position ?
                            I manage to get the on sale fuel pump
                              yes
