Question on submarine ballast need help
    I am planning to make a submarine, diameter about 16 cm and about 30cm in diameter. (2 Lock n Lock tupperware containers). Would like to ask if a 140 cc (5oz) syringe filled with water act as a good ballast for bringing it down? Thanks for your help!
    Hangar:
    IJN Yamato (RC, EP)
    fitted with workable searchlight
    1/350 Tamiya,
    converted from static
    DKM Bismarck (Static)
    USS Missouri (Static)
    Shipyard:
    Schnellboot S-100 Klasse (RC, EP)
    USS New Jersey (RC, EP)
    Home Waters: Tanah Merah (my condo)
    Boating hours: 9.30pm+ (night ops)
    cannot throw in some fishing weights ? sure sink
    then want to surface.. cut off the lines and drop the weights into the water.. like the ancient submarine style... hehe
    I'm Remotely Controlled ...
      Have considered getting a bilge pump to pump water in n out of ur ballast compartment???
      I remember seeing r/c bilge pump for sale on ebay.
        Found it!!!
        Here :
          Originally posted by Adrianli
          Eh dun wan to use a bilge pump, use syringe since already bought... Can sink or not?
          Hangar:
          IJN Yamato (RC, EP)
          1/350 Tamiya,
          Shipyard:
            Never built a Sub b4. Not sure can float, but sure can sink to the bottom. Better do proper calculations.
            I do have two RTR toy Subs thou.
              Heys do you know anywhere in Singapore (not Ebay) which sells those bilge pumps? Need something around $20 or less and needs to be reliable. Fish tanks one can or not? Need to be able to sustain a vacuum when pumping out water.
              Thanks for your link though
              Hangar:
              IJN Yamato (RC, EP)
              1/350 Tamiya,
              Shipyard:
                Sorry, I have no idea of any r/c bilge pump.
                But I do know where to get real ship's bilge pump. Either powered by D.C, A.C or Air. These would be too big for any r/c purpose.
                  Regarding your question about using a ballast tank based on syringes- Yes, it can make your sub sink. Take a look at this site.
                  It shows you the different kinds of ballast tanks and how to build a RC model submarine.
                  make it simple, make it strong, make it work!
                    Lastre regulable SUB RC / RC SUB adjustable ballast
                    i saw this few days ago.. u might find it useful
                      Check out www.arkmodel.com
                      My saliva is dripping!!!!!!!!!!!
                        Thanks, managed to get a 6V-powered pump at pet safari today, hopefully it works fine
                        Have another question - I am currently using a prop shaft stylized in the method used for boats, ie outer shaft inner shaft grease. Does not seem to work for subs at a greater depth. Would O rings solve the problem? How should I place the O rings? Thanks!
                        Hangar:
                        IJN Yamato (RC, EP)
                        1/350 Tamiya,
                        Shipyard:
                          Don't think fish pumps can work... least those small sizes ones.. because the moment I put my fingers over the expel-side of the pump the pressure was actually quite low.. i doubt the the pump could ever push the water out and leave a vacuum in the hull.
                          connect syringe to a high torque servo and squeeze water in and out of the syringe could be a better choice..
