DIY EDF plane & pictures
    Hi , decided to created this thread so that anyone can post your pictures of your DIY EDF plane and discussion.
    To "kick off" is the pictures of my own design EDF plane .
    This plane uses modified 55EDF on 3 blade rotary blade from a cut down 3 blade 9-7 prop... and a 5.4KV mtr from R Hobby.
    Run on 3S 1800maH lipo drawing a max 17 amps of current at over 54,000rpm.
    Estimated thrust is over 400grams.
    Maiden sucessfully this morning. Plane is Fast but control throw is a bit sensitive. Need to reduce the Elevon throw setting. Make only one flight because the sky was dark and cloudy.
    Plane:
    Plane uses a 6mm Dupron and a 3 mm hollow C.F rod to stiffen and strenthened the wing. Wing is a basic delta form.
    Fuselage is a 5mm dupron externally lined with 0.5mm ply, side and bottom.
    Bottom fuselage waterproof using a 3.5 inch packing tape. This will allows light weight and yet a strong fuselage.
    Top fuselage uses a 7-12 oz styro cup cut join and shape accordingly. This will reduce drag and improve flying speed if done properly.( Next time don't throw away the styro cup) ...maybe I should call this plane "Flying styro cup"
    heh! heh! heh!
    RTF weight with the LIPOS is 395 grams.
    Goodwork Bro! nice of you to share DIY stuffs!
    Cheers! See you around.
      Thanks bro, may post more pic and video when I got the time.
      Now thinking of building a bigger DIY version using a 70mm Kamdax or 68mm SFM. Just need to find time. Too busy with work.
        hi my diy..a little more conventional and less experimental compared to yours.
        ..i less daring le....
        cheers.
          Aeroswift Flying Wing
          Here's mine, just a distant memory of a DIY
          GWS EDF 55 Himax 2025 4200 (I think)
          Kokam 3s1p 2000
          MGM Pro 25amp
          GWS Pico Standard servos (cheapskate)
          Wingspan: 40 inch
          Flight characteristics:
          flies on a rail type, launches easily, light wing loading, floats around fairly well. Quite speedy too.
            Hi Bro, very nice pictures and very creative. Keep them rolling. I am building another EDF DIY plane using a bigger fan. Just cut out and join the main wing yesterday. May post some more pictures once they are ready.
            Put in some basic info like power plant, wing span and flying characteristics will make this discussion more interesting.
              my other diy EDF
              Hi, here is my other DIY EDF.
              Wing span 30 inches
              Wing area 190 sq in approx.
              Power plant=68mm EDF from SFM 6 blade.
              Motor=walkera 380S
              Max current with 3S lipo=22-23amps
              Weight=510grams
              WTTR=greater than 1
              Flying: Maiden sucessfully last weekend.
              will be constructing another DIY EDF as my future test bed for my Kamdax EDF ...coming soon.
                My other twin DIY EDF plane
                Hi, just completed another project using twin GWS 55 mm EDF.
                The twin uses 2 x B20-40-3.2KV brushless motor.
                Plane weights 585grams.
                Holding the plane vertically and power up, thrust is strong most probably exceeding the plane weight.
                Just to find out more, I added another battery as weight so that the plane now weights 713grams. At full throttle with a good 2100mAH 3s1p lipo thrust is still strong to lift this weight with room to spare.
                Measure initial current around 25amps and will drop to around 22-23 amps after a minute of runs.
                Will be carrying more test.
                More later.
                  Twin ESCs leading into the motors? How do you connect batteries? Sorry I'm a newbie. Daydreaming of a quad EDF X-wing model.
                    Hi Sunstorm, I suppose you means twin Brushless motor setup.
                    go to http://www.daddyhobby.com/forum/show...7&page=3&pp=15
                    thread 32.
                    Most of the time you need two sets of ESC for the two Brushless motor setup
                    You need a Y harness connectors between the two ESC and receiver.
                    You may need to remove the +5v from one of the ESC and leave the other +5V lead for the receiver.(there are exception).
                    Babylon5
                      Sorry I miss out your real query. Attached is the picture showing how the batteries are connected to the two ESC.
                      The Y harness are not shown in this pictures.
                      Cheers and hope this will help.
                        More on the twin DIY edf plane
                        Try to maiden the twin this morning. Suffer instability problem so plane came down with some minor damaged.
                        It did reamained airborned but boy I was fighting the controls like crazy for about half a minute.
                        Looks like the main single vertical fin in the central axis is not enough. Will modified to a twin fin set setup. Winglet at the tip will remain for better stabilities.
                        May try with a pusher configuration before trying the twin EDF set up again.
                          Twin EDF with twin main fin continue
                          Modified the plane with a twin main fin. Flew sucessfully with a pusher configuration. Plane was very much stable. Was able to trim the plane during flight.
                          Have replaced the pusher to a proper twin EDF setup. Will try again when the weather is ideal for flying.
                          Attached is the picture of the twin main vertical fin and the 2X55mm EDF GWS .
                            Another DIY EDF of my own creation
                            Here is another EDF of my own creation.
                            Decided to built it light weight by going profile.
                            AUW ready to fly is 290grams give and take a few grams off.
                            Uses 3s lipo 1200maH 15C and a 55mmEDF 3blade from Himodel on a 3.8kv tahmazo 20-xx motor.
                            Max current around 9.5-10amps .
                            Thrust greater than the weight of the plane.
                            Hope to maiden this weekend.
                              All right man! One up for the Decepticons!
