Check List for Safety Reason
This is a sticky topic.
    Pre-Flight check
    1. check all your screws
    2. check your servos movement
    3. check all the wires to see whether is there any cut on it
    4. check your connection, make sure nothing is lose
    5. check all the control rod
    6. check the linkage to see whether is there any crack
    7. check your control horn
    8. make sure your wires are not to tight or to lose
    9. check all the fuel tubes, even those inside your fuel tank
    10. make sure there is no or not alot of free play on your head n rudder
    11. make sure your Tx or Rx batts are fully charge
    12. every 2 - 3 gallons check your glow plug
    13. if u on belt drive, make sure the belt is not lose. For gear drive, make sure your screws on the gear is tight.
    14. check for binding
    15. check your gyro, make sure is not lose
    On Field
    1. check your radio fq n check with everyone make sure is clear
    2. recheck all the linkages
    3. check your radio programes, incase someone touch n change your setting
    4. check your batt level
    5. recheck your wires coonection, incase during trevelling the wire came lose
    6. recheck your servo movement
    7. check your fuel level
    Starting
    1. check your throttle stick
    2. make sure is on normal mode
    3. move all your stick to check whether all the servo moving anot
    Taking off
    1. rmp your engine up, don't take off first
    2. check your control whether all moving anot
    If all this are check u r safe to go.
    If i miss out anything, feel free to add in.
    [B]Kenny[/B]
    would like to add a few safety tips that i use...
    1)if possible, buy some dental floss and use it to tie up connections. its cheap insurance against plugs and wires coming out.
    2)tie down components with rubber bands. i use those livestrong kind of arm bands to tie down receivers. they are just the right size and tension.
    3)make sure your wires are routed such that when a servo moves, the wires would not get cut.
    4)if not sure about integrity of aerial during transport or area due to proximity to other sources of radio noise, do range check.(antenna down, walk to 20m without glitching or going into fail safe)
    5)do a once a week post flight maintenence while cleaning your heli. i find alcohol from pharmacies removes exhaust oil well. while cleaning, just check stuff out. the alcohol removes oil which may enter servos and foul them up
    that's about all for now...safe flying for everyone
    JR 9x
    Raptor 50 SE
    Raptor 90 3D
    Mini-Titan
    Superb machine!
    Piper Warrior 2 Pa-28-161
    Lycoming O-320-D3G 160HP
    Pilatus PC-21
      For new comers, if u first time starting a nitro heli, never start it yourself. Let the more experence to show u how to start. If not it will be dangerous.
      [B]Kenny[/B]
        Do not fly 3D over the runway.
        Do not fly over other people head.
          Check List for safety reason
          Hi sookainian brandon yapjy tanks your guys good suggestions for all new & old flyer,s I print it out for RF.
            Safety Reason
            Originally posted by sookainian
            Pre-Flight check
            On Field
            Starting
            Taking off
            can I print out your suggestion give toflyer
              feel free
              [B]Kenny[/B]
                New batteries.... safety first!
                OK, NIMH cells batteries need to be charged at 0.2 amps... should take about overnight...
                am not sure abt Nicad... please do not whatever over look this...
                i experianced a crash without doing it(cuz i was not informed about it), and i dont want anyone to go through what i went through...
                sar.ratha@me.com
                DEVIL
                  Hmm charge over night at 0.2amps or charge and decharge the batts like 4 - 5 times.
                  It happen to me twice before, luckly i never crash. Last time when i got my new Ni,Cad Batts then i ask my friend test flight, then suddenly the batt went dead but i remember i did a full charge b4 i left the house. but luckly never crash, manage to land it down.
                  The 2nd time it happen to me was around 1 - 2 weeks ago. when i was testing my new bird with the new Rx futaba batts, i also never do the 'cycle' then after 1 min of hovering, suddenly engine went dead, and luckly it 'auto' down nicely & softly. Then later i tried to start the engine again. Then i relise the batt is dead
                  [B]Kenny[/B]
                    Some safety tips
                    1. check all batteries ( TX and RX batteries) make sure they are all slightly above the safety point of usage
                    2.After taking off, u may want to hover awhile just to make sure the fuel from the main tank flow into the spare tank.
                    3.if u are doing 3D and u find the cyclic not as responsive or the tail not holding as usual, the battery might have flatten, land the heli and check the battery voltage.
                    thats all for all now guys cool & safe flying
                    JR 2.4GHz 10X
                    JR DS8717
                    Solid G
                    KY-3000 30% nitro
                      Mb you guys also want to take note of ball links screws. It will come lose after some time.
                      [B]Kenny[/B]
                        It will only come loose after some time if you didn't locktite it in the first place.
                        F5D Stratair Demon
                        F5D Jibe
                        Jiri Bachinski Escape Pylon
                        Voodoo S400
                        Kyosho Phantom 70 Reno racer
                        La Racer 56
                          haha. thanks! but usually kenny. you straight away from ground idle 2 then shoot one leh! haha.
                          Kedi AH !
                            newbie
                            Thanks to everyone.
                              thanks to all gurussss...
                              It is normal when I chank start the engine, once it have a loud pop sound?
                              "Never Argue with an idiot, they will pull you down to their level and win you with their experience"
                              DXS9
                              Raptor 50 fully blinged
                              Peigon 450 fully blinged With Airwolf fuselage
                              ME109
                              Wilga 2000
