Yet another warbird to join the war...... The manual from that came with this ARF is well prepared and detailed. Very well illustrated and explained.
P-47 Thunderbolt .60 from ModelTech ARF
I started work on it at various stages and not all the photos are in series and /or sync with timeline.
Started off with the cut-outs for the aileron and gear and drilled 1,5mm holes for the wood screws. Alot of trimming was required to fit the aileron servo panels as they were not entirely a perfect fit.
Retracts were optional and is going to be the Landing gear for this plane.
Notches filed on the metal rod to receive the retaining collar screw on the landing gear. The four cap screws for the tail wheel was a real pain as the space was small and the alignment was a bit out. So I have to sit there for at least 30mins and slowy wind the four screws in bit by bit alternatingly.
The retracts fitting were good, a bit (4mm) of slop after retracting full close, but I think its normal, as long as the wheel don't fall/hang out whilst in flight.... The included retract link rod turn out to be exact , not much access to trim after going thru the rotating brass retainer. I am worried that its too short....sigh.
Originally posted by AstroBoyWould you consider putting in an oscillating PERRY pump?, so that you don't need to hang out the stock exhaust muffler, the advantages are :-
1) it would be more scale-looking
2) the exhaust sound would be EVIL!
3) best part of all, it would release some extra horses hidden in the Saito100
Of course, its only less than $200/-....why not! Only the owner can decide on this though....
