Rc Jets
    ................. maybe this video show will have all the answer. Just go to the video site. Very nice and very BIG F-14 Tomcat.http://www.jet-team-liebetrau.de/Produkte/F14/index.htm
      from what i know, the GSU controls everything. the throttle is placed from low to high to initiate the start sequence. once the unit detects this, the electric motor will start spinning the turbine shaft. propane is fired in to warm it up and let it spool up some more. once at about 250degC, the kerosene kicks in and soon the turbine becomes self sustaining, whereby the motor cuts off. throttle stick is brought to low again and normal operations can be done.
      JR 9x
      Raptor 50 SE
      Raptor 90 3D
      Mini-Titan
      Superb machine!
      Piper Warrior 2 Pa-28-161
      Lycoming O-320-D3G 160HP
      Pilatus PC-21
        Seem to be a very interesting things to learn about jet engine.Because I never know turbine engine got so many things on just the jet alone.
        Jameswilliam
          job on 13-11-2004
          wing cutting prepare for sheeting, cut off LE and TE. The wing root part are design one piece with fuselarge.
          jason
          Team RCFlipMaster
            02
            Team RCFlipMaster
              03
              Team RCFlipMaster
                04
                Team RCFlipMaster
                  Vacuum pump for Vacuum Bagging process use......this pump are given by my america friend ( Ray ) 110Volts so need a converter to operate it.
                  jason
                  Team RCFlipMaster
                    Balsa sheet wait for joining into big sheet.
                    jason
                    Team RCFlipMaster
                      07
                      Team RCFlipMaster
                        08
                        Team RCFlipMaster
                          Goh's Kangaroo at the background, all the stuff will move to new trainer jet.
                          Team RCFlipMaster
                            10
                            Team RCFlipMaster
                              11
                              Team RCFlipMaster
                                Thanks to Makuang for all the photos. post all this using his computer "in hurry rush to going home" Thanks again Makuang.
                                Jason
                                Team RCFlipMaster
